SINPO Rating 1-5
International DXing - English language forum
Модератори: DX-er, Георги
predavatel
SINPO Rating 1-5
Мнениеот predavatel » 13 Ное 2009, 19:22
SINPO Rating
Your chance to give 'marks-out-of-five' on how badly degraded the signal is by interference, noise and propagation effects respectively. The definitions for the degradation effect are shown as Extreme (1), Severe (2), Moderate (3), Slight (4) and Nil (5). It might be helpful to consider that in the RS(T) reporting system we use R5 to report a perfectly readable signal, and R1 for a signal that is unusable. With SINPO all we are doing is splitting the "R" report into its individual components I, N and P:
"I" stands for interference, or QRM. Think about this as a reading for the degrading effect of interference on the QSO, i.e. 5 for none, 1 for a lot. When giving the report you can think the same way as you do with the "R" report for RS(T) - for a signal with very heavy QRM you give it a report of 1, and a signal with little or no QRM gets a report of 5.
"N" is for the degrading effects of noise, i.e. QRN. Again we can think about the report as 5 for none, 1 for a lot. Note that interference from a broad-band data transmission might sound like noise, so if you can do some checks to ensure that you gave correctly determined whether the apparent noise is indeed noise rather than QRM.
"P" is a measure of propagation-related distortion such as fading, flutter or perhaps an auroral rasp on the signal. Again, it is seen as a measure of the degrading effect on the desired signal, also scoring 5 for none, 1 for a lot. This is perhaps the more difficult one on which to report, as on a strong signal the effects of QSB may be less noticeable with the good AGC systems in our rigs these days. Conversely it could be that you hear more pronounced fading from QRP stations and therefore give a different report for P between QRO and QRP stations.
Finally, the O report is a measure of the extent to which all these factors contributed to the overall rating; 5 for excellent and 1 for unusable. O=1 is also used for “not heard”; when it is known that the station is transmitting on channel. SM.1135 has a useful set of tables to help the assessment of O. Table 3 below shows the assessment suggested for telephony transmissions:
ITU SM.1135 SINPO Reporting Code for “overall” assessment of a telephony transmission.
Sources: ITU, RSGB and The Listener's Guide by Bob Ellis
Happy DX-ing!
BoskoIgic
Re: SINPO Rating 1-5
Мнениеот BoskoIgic » 13 Ное 2009, 20:22
Example:
Radio Romania Cultural 89,5 in Bela Palanka
Distance:251 km
Terrain:2-3
S=3
I=5
N=5
P=4
O=2-3
Energy 89,5 in Bela Palanka
Terrain:1
S=1
I=1
N=1
P=2
O=1
Мнениеот LZ2GPB » 02 Авг 2012, 23:50
@Bosko, it's not possible to have a SINPO of 35542, but 35543 or more likely - 35544. When you don't have interference, noise or perceptible propagation distortion (fading), the overal listening experience (the last number of the SINPO code), should be at least 4. :)
