HD Radio
Има ли почитатели?
Re: HD Radio
Мнениеот LZ2GPB » 30 Сеп 2014, 20:28
az написа:А някой има ли представа дали има (или ще има) експериментално излъчване на AM HD в Европа или поне в радиус до 2000 км. около България с идеята да се улови вечерно време?
Подобни експериментални емисии засега се излъчват само в Северна Америка, главно в Щатите. http://www.everettpost.com/KRKO-and-...gital/20005777
gat3way
Re: HD Radio
Мнениеот gat3way » 19 Окт 2014, 18:00
Сега четох мнения по въпроса за това и като гледам не е особено прекрасна работа...
It's also (what I infer to be RSA) encrypted on top of using an incompatible, modified version of the AAC codec. The stations have to pay annual fees (hinted at $22,000 per station) to get the next monthly encryption key or their station will be refused to be decoded by normal, non-blacklisted HD-Radio receivers. The HD-Radio standard is assumed to includes the ability to blacklist known "untrustworthy" receivers.
I have a dongle for my iDevices that would normally be of interest to modify, but it requires a binary firmware upload from the iDevice app when being turned on. All sound comes out a 3.5mm jack in the dongle rather than piped through the iDevice. I bought the thing on sale for $35 and still got ripped off...
Get the insignia portable or a non-factory radio for in your car. Don't waste more than $20 for anything that only does HD-Radio FM. The channels drop out constantly on the move, dropping you back to the analog station; then it's silence while enough data is collected for decryption. More money may be worth it for something like the Hi-Fi decks that are capable of tuning HD-Radio on both AM and FM if you really want to listen to it at home with an outdoor antenna. And get your first one used.
...Endorsing this standard was a mistake for the US. We here should have endorsed an open standard, not a proprietary one.
So, US does not have a digital broadcasting format thats free and widely used! We're way behind the rest of the world in that respect.
In Europe, Asia, etc. at least one different digital radio format, DAB is free and popular..
Re: DAB приеми - на Балканите и другаде.
Мнениеот radiolubitel » 25 Фев 2016, 15:23
Гледам,че и в Букурещ вече има HD-радио на 100,6 МХц. Интересно с каква мощност излъчват и дали на Витоша с по-добра антена няма да се хване? ;D
Мнениеот Георги » 25 Фев 2016, 16:19
HD радио в Букурещ има от 4 години, писали сме за това тук тогава, и ти включително - viewtopic.php?f=101&t=537&start=500
http://www.mediafax.ro/cultura-media/pr ... hd-9934927
Интересното е, че на тази страница http://hd-radio.ro/# обявяват и други градове в Румъния, в които има такова излъчване.
Re: HD Radio
Мнениеот Георги » 09 Мар 2016, 22:52
Радвам се да споделя с вас първите си приеми на HD radio сигнали, и то от два града в съседна Румъния.
Първият е Констанца, откъдето имам две видеа с прием на този странен за континента ни сигнал:
1. - https://youtu.be/4pC2Eg3th2E
2. - https://youtu.be/1CUZGsm20J4
Вижда се, че честотата на излъчване в този град не е 91,1 както е посочена на официалния сайт - http://hd-radio.ro/, а е 103,9.
Вторият е от столицата им, където освен аналогов сигнал на Рок ФМ на 100,6 има още и 4 HD станции - https://youtu.be/Q4NdGPlJffw Освен това съм заснел и DAB прием, показвайки как Румъния е уникална страна в света, в която има и DAB, HD Radio и DRM! (Само последния стандарт все още не съм го хващал, мързи ме да ровичкам компютъра с един тунер-флашка)
:ro: :Good
Re:Мултистандартно радио
Мнениеот popovp » 20 Май 2016, 09:14
Тунер чип на Parrot за многостандартно радио - AM, FM, DAB, DAB+, DRM, DRM+, DVB-T2 Lite and HD Radio, приложимо за автомобили:
http://www.parrotautomotive.com/en-gb/n ... solutions/
Re: HD Radio
Мнениеот ЖОРО » 26 Апр 2020, 17:57
Джорджи™ написа:HD Radio на ФМ честоти от горните линкове не звучи кой знае колко добре.
ФМ никога не може да доближи кристално чистия звук на DAB+.
При ФМ винаги има фонов шум или брум, и реже най-ниските, най-високите тонове, както и детайлите в звука.
Най-тъпата и зловредна технология е ФМ. Трябваше да се премахне напълно през 2006 г. още.
то пък в даба си мислиш че няма орязване . хахахахахаа смешник
Re: HD Radio
Мнениеот Stani » 26 Апр 2020, 18:40
Имах записи на касета от едно радио и песента записана от там сравнена със запис от оригиналният албум почти не се отличаваше от оригинала, при нормална девиация и достатъчна мощност на предавателя се постига добро качество, а при добър процесинг честотната характеристика не се изменя, укв предавателите имат добра честотна характеристика относно модулация и няма орязване нито на ниски, нито на високи, ако разбира се всичко е направено както трябва.
Re: HD Radio
Мнениеот ЖОРО » 26 Апр 2020, 19:22
При ФМ след 13.500 за среден клас предаватели е желателно да няма нищо
само най добрите може да издържат до 14.500 килохерца
иначе ниските средния клас предаватели са от 50 херца нагоре
най хубавите са до 42-45.. херца
иначе при Даба е почти същото само където честотите може да ги смъкнеш до 38-15 килохерца.
просто по нагоре не ти трябва..
сателитното е същото . всичко след 15 килохерца се орязва ако е емпегнат сигнала.. иначе ако го минеш на АС-3 може без проблем да лъчиш и над 15 обикновено стига до 18-19 килохерца.
Re: HD Radio
Мнениеот lunar_light » 26 Апр 2020, 23:17
Човешкия слух е между 16 и 20 000 hz, ако ще и до 300000 hz да възпроизвежда e все тая.
Re: HD Radio
Мнениеот минстрел » 30 Апр 2020, 22:19
Усеща се разлика и между слушалки, които "вдигат" 22000 Hz и 20000 Hz.
