DAB/DAB+/FM приемници
Been thanked: 70 times
Мнение от popovp »
Предлагам да пишем в темата за това какво съдържа кутията на приемника - предимно данни за процесора, тунера.
Отваряйки моя нискобюджетен Renkforce NE-6208 виждам следното:
Процесор с инрегриран тунер
Frontier Silicon KINO4 FS 1445-A
FSN09281.000
U3H1625
Подобно на
Някои технически характеристики:
Kino 4 is the latest generation of low-power integrated digital radio system-on-chip (SoC). It is a fully integrated single chip radio receiver SoC containing RF tuner, baseband, application processor, audio decode and DAC functionality.
Kino 4 has been designed to power all major categories of consumer digital radio device from simple portable digital radios to home audio systems in either a master or slave configuration.
Containing a number of innovative technologies to optimise power consumption,
Kino 4 uses up to 50% less power than the previous generation Kino 3 chips. The high level of integration such as built-in voltage regulators help to reduce the system component count and keep BoM costs to a minimum as well as reducing manufacturing time.
Kino 4 is Digital Tick compliant. The on-chip multi-band RF tuner and processor operate in the following RF bands; LW/MW/SW, FM, DAB-III and DAB-L.
Summary of Benefits
Enhanced performance and functionality
Up to 50% lower power consumption than the previous generation Kino 3
Reduced cost
Designed to power all major categories of digital radio device
Supports all major digital radio broadcast standards
Supports all digital and FM radio frequencies
FEATURES
• CPU 360MHz META MTP
• RF Sensitivity: DAB -100dBm, FM
-110dBm
• On board RF tuner supporting, Band III,
Band II.
• Internal Stereo DAC with 90dB dynamic
range
• Boot from internal memory, SPI flash
memory or host device. Software
configurable
• Flash memory interface
• Temperature range
ƒ Operating -40 to +85 °C
ƒ Storage -40 to +125 °C
• Full RoHS compliance
KINO 4 FS1445
Highly-integrated DAB/DAB+ digital radio processor
© 2016 Frontier Silicon Ltd. March 2016
EXTENSIVE INTERFACES
• Multiple configurable GPIO and ADC
inputs
• S/PDIF audio output
• I2S input/output of decoded audio data
(both master and slave modes)
• Support for multiple SPI slave devices
• 2 x 16550-compliant UARTs with
optional flow control
• Colour LCD/OLED supported via SPI/
I2C or LED indicators for headless
display.
• GPIO and ADC interfaces
• JTAG interface for test and emulator
support
Kino 4
Audio
DAC
RF
tuner
GP I/O
META MTP
CPU/DSP
Clock
SRAM I2C/SPI
USB 2.0
RF
Keypad/
Controls
Display
Analogue
Audio out
Digital
Audio in/out
I
2S
RF
Keypad
LCD
Kino 4
USB 2.0
Audio output
Display
FM
DAB
AUDIO
DATA
SIMPLE DAB RADIO APPLICATION
Т.е. представя се като сравнително евтин, икономичен(с малка консумация ок.50% по-малка спрямо предната модификация KINO 3) приемник.
Re: DAB/DAB+/FM приемници
Мнение от popovp »
След преработката добавяне вход за външна антена вече изглежда така:
В резултат ъпгрейда:
https://www.youtube.com/watch?v=5lZAi5d29-A
Мнение от popovp »
Използвам заглавието на темата да информирам за развитието на комбо ДАБ+/ФМ... приемниците Sangean
Sangean Revery R6
Със своя флагман Revery R6 (DDR-66BT), радио специалистът SANGEAN иска да постави нови стандарти в сегмента на радиостанциите "всичко в едно". Опакован в благороден дървен корпус, който според производителя е адаптиран точно към високоговорителите за фини височини и пълни баси, Revery R6 гъвкаво обслужва желанията на любителите на радиото и музиката на луксозния аудио стил.
Също така на борда са DAB + и FM приемници, уеб радио и приложения за стрийминг на модерните платформи на Spotify, Tidal, Qobuz, Deezer и Napster. Аудио стрийминг чрез Bluetooth, вграден CD плейър и MP3 възпроизвеждане от различни носители за съхранение, за да направят многофункционалния Revery R6 универсален в аудио полето.
„Използването на аудио днес се осъществява много индивидуално: Много слушатели искат бързо и безпроблемно да избират между наземно радио, Bluetooth стрийминг, хип платформи, техните компактдискове и техните собствени MP3 песни. Това прави флота на оборудването нарастващ. С Revery R6 представяме всеобхватно и стилно око, което съчетава тези изисквания с възможно най-доброто качество на звука в едно устройство с благороден дървен корпус. Многостайната възможност също така позволява R6 да се използва като удобна домашна база. Maurice Wijnands, продуктов мениджър в SANGEAN, казва: "С това всичко-в-едно устройство, ние предлагаме швейцарски армейски нож за съвременни аудио наслада и нашите клиенти, благодарение на най-доброто качество на звука и всеобхватни функции, влизането в поколение 4.0 DDR-66BT.
Едно устройство, много радио и аудио източници
Линейното радио е предназначено да приема Revery R6 чрез FM, DAB +, IP (всеки 10 бутони за памет) или чрез най-горещите платформи за стрийминг, включително Spotify Connect. У дома, благодарение на поддръжката на DLNA, съдържанието на мрежата може да бъде предавано към приемника (наличен е Ethernet порт). Вграденият CD плейър позволява възпроизвеждането на собствена аудио библиотека (MP3, AAC, WMA), както и извличане на аудио данни към SD памет или USB носител. Носителят може да се използва и за възпроизвеждане на MP3 файлове или запис от радио и други аудио източници. MP3 плейърите могат да бъдат удобно свързани чрез Aux-IN. Разбира се, също може да се предава чрез Bluetooth към устройството. Използваният aptX кодек осигурява най-добри резултати по отношение на звука.
За UNDOK App, универсалният в нито един момент Multiroom-съвместим и осигурява свързаните устройства за възпроизвеждане в домашната мрежа с всички аудио ресурси. Приложението също отключва аудио файлове от смартфон и таблет за възпроизвеждане на Revery R6. Свързването на други звукови тела може да се осъществи по традиционен начин: Line-OUT позволява класическо свързване на жични високоговорители.
Удобно оборудване
Прецизно изработеният дървен шкаф, който беше акустично настроен към високоговорителите, създава мощен и балансиран звук. Фините мелодии могат да се правят и чрез вградения еквалайзер чрез предварително зададени настройки или свободно избираеми с функцията MyEQ. Лесният за четене, 3.2-инчов TFT LCD дисплей с подсветка осигурява цялата информация, многоцветна, необходима за работа.
SANGEAN придава голямо значение на настройката на тунерите, които трябва ръчно или автоматично да прецизно излъчват радиовълните от етера. Функцията за автоматично сканиране улеснява търсенето. Интегрираният часовник ще бъде снабден с данни за точното време през IP, VHF и DAB +. Двата таймера за аларма (радио, зумер, свързан носител) трябва да поемат класическите и все още незаменими функции на алармата. Инфрачервеното дистанционно управление допълва комфортния пакет за оборудване.
Revery R6 / DDR-66BT вече е на разположение при MSRP от 629, - евро.
https://satvision.de/aktuelles-und-news ... ry-r6-7800
Has thanked: 627 times
От днес съм собственик на радиоприемника Pure Еlan Connect, който поддържа FM/DAB+/Internet Radio/Bluetooth:
https://www.amazon.de/-/en/gp/product/B ... UTF8&psc=1
Приемника го поръчах от amazon.de на 19 март и го получих днес на 26 март (точно за една седмица пристигна от Германия) :clap:
Има си цветен 2.4инча TFT дисплей (показващ картинки), възможност за ръчна проверка на сигнала по канали (за DAB/DAB+) и еквалайзер и мога да кажа, че радиото е по-малко на размер от Panasonic RF-D10, а звукът му е по-добър (дори доста добър за размера си, с доста басове) :D Разликата в цената е около 10-20лева. Радиото работи на контакт със зарядно на нормален андроид телефон и може да се пренася с наличие на 4 бр. батерии тип AA (скоро ще се сдобия с такива, които ще презареждам). Към този момент имам впечатления главно от интернет радиостанциите. Има разнообразие от български радиостанции, като учудващото е, че радиостанциите на BSS/United Group (Витоша, Веселина, The Voice, Magic FM) тотално липсват, а налични ги има например Радио Белла, Фолк Айтос, Power FM Бургас, Зорана и др. С най-добро качество (MP3 висок битрейт 320kbps/с много добър звук) ми направи впечатление, че са Фокус и Мая (за мен перфектно).
Скоро предстоят тестове в FM и DAB/DAB+ (може да направя сравнение на приема на Букурещ в разградско) обхвата като ще направя и проверка на истанбулския DAB+ в района на Аксаково/Варна, който от доста време липсва - заради новата кула и метереологичната обстановка най-вероятно :think:
Видео:
https://youtu.be/StuvX_be40s
Мнение от popovp »
Честито нова придобивка! Със здраве да я ползваш и изпитваш удоволствие от приемите!
Очакваме ДАБ+ клип от румънците. Турците все-още не са пуснали.
Has thanked: 18 times
Been thanked: 26 times
Мнение от stankos »
76 Евра са си много пари! Колко чинат най-евтините варианти?
popovp написа:Честито нова придобивка! Със здраве да я ползваш и изпитваш удоволствие от приемите!
Mного благодаря за пожеланията и информацията :)
И аз предполагах, че може би все още е изключен истанбулския DAB+ - радвам се, че писа и съобщи категорично. Като цяло новата кула ,,ни видя сметката" и слабо излиза над Аксаково, но аз лично за ориентир както и преди съм свикнал използвам Radyo Seymen 107.0 (гледам хем да тествам, хем да слушам нещо с удоволствие и не мога да стоя на 107.4 Voyage). Скоро ще покажа прием на DAB+ 12A от Букурещ....
Stani написа:Честито и от мен, богат "улов", наслука!
Благодаря :)
stankos написа:76 Евра са си много пари! Колко чинат най-евтините варианти?
С какво търсиш да бъдат оборудвани най-евтините варинати - само FM/DAB/DAB+ или да има и интернет радио към него. Като цяло добре се бях разровил в амазон и това най-много ми допадна, като цена-качество (това което предлага). На същата цена (70-75евро) наистина има доста по-лоши приемници и плюсът на амазоне е, че в коментарите има много мнения на хора, изпробвали продукта ;)
От България лично на ниска цена съм пробвал Denver DAB-42 на цената от 30лева и си бях доста доволен:
https://www.olx.bg/d/ad/digitalno-radio ... 9ac1a3a1e5
Лично мое видео:
https://www.youtube.com/watch?v=m1CYUjfSWEw
Eто ти линк и към amazon.de с DAB/DAB+ приемници:
https://www.amazon.de/s?k=dab%2B+radio&ref=nb_sb_noss_2
Има приемници на всякакви цени (много скъпи и много евтини), но вече кое е сполучливо и дали ще ти върши работа ще си решиш ти...
Иначе ако сравним повечето DAB+ приемници на пазара, моят нов като цяло не е толкова скъп, за това - което предлага ;)
Ако търсиш нещо скъпичко, заповядай:
https://www.amazon.de/-/en/Sony-XDR-P1D ... 373&sr=8-2
Toва е джобно, но приема доста слабо, като цяло лош звук, не показва картинки, няма ръчен индикатор на DAB+ каналите, няма Internet Radio и Bluetooth, а разликата в цената между него и новото радио е около 15-20лв - сам си направи сметката :D
Has thanked: 241 times
Мнение от stankos »
ShukiBG написа: С какво търсиш да бъдат оборудвани най-евтините варинати - само FM/DAB/DAB+...
Предполагам това плюс възможност за включване на външна антена и извод за слушалки ще ми е достатъчно !
Става въпрос за играчка, която ще се ползва крайно рядко...., когато скучая някъде докато си почивам на море или планина, или на вилата, или не знам... ;)
dstb
Регистриран на: 08 Юни 2020, 20:38
Местоположение: Бургас, Bulgaria
Has thanked: 4 times
Been thanked: 9 times
Мнение от dstb »
Здравейте колеги,
Да ви се похваля чв тези дни и аз се ДАБифицирах :)
Взех си от продавалника Eletra ETUNE16W, което явно не e популярна марка.
Радиото изглежда точно като това, само че е бяло. Версията на софуера е dab-mmi-FS2445-0000-0438_V6.1.8.EX66155-1A1.
https://www.youtube.com/watch?v=JsVD0ZJWwNQ
Мнение от ogibo »
Днес видях в Лидал кухненско радио Силвър крес за около 50 лева.
Has thanked: 152 times
Been thanked: 71 times
Мнение от tekotien »
Мойто радио се казва марка DENVER и си го купих за 29 лева . и си бачка перфектно нямам забележки, само че ми хрумна една работа , до сега използваните радио применици имаха , следните обхвати средни , дълги , къси и укв/фм , обхват , сега с тоя новия стандарт даб+
чудя се не мога да намеря принципна схема , ако реша примерно да си направя сам да си сглобя , иначе за другите обхвати принципни схеми колкото искаш в нета ,а за даб+ приема няма не знам защо ? ако някой знае къде има моля да ми даде линк мерси.
Това е моето радио !
Мнение от popovp »
Примерно
irinastefanova825
Регистриран на: 18 Яну 2023, 00:46
Мнение от irinastefanova825 »
това е готина джаджа, която си взех наскоро Baseus Energy зарядно за кола с FM радио приемник
